I think that if someone has an issue with the car changing ends during a panic stop the cause is going to be either, overcorrection by the driver, brake or suspension problem front or rear, serious alignment issue, etc.
JMHO, but tread depth has nothing to do with sliding but the tire compound could have something to do with it.
Being a front wheel drive , it sounds as though both front wheels are not pulling equally as if it’s a problem in the differential. Maybe ? Reminiscent of the rear axle opperation with no positrak, just one side is driving. Does it always fishtail in the exact same direction ?
