So McPherson struts are only used in the front suspension, never in the rear?
A strut controls the dynamics of the wheel through its movement. It generally bolts directly and robustly to the steering knuckle in a way that keeps the spindle at the angle the designer intended throughout its vertical movement. A strut will rotate only around the steering axis.
A “coilover” does not control the movement of the axle beyond absorbing bumps. It simply combines the spring, which supports the vehicle as well as absorbing shocks, and the shock, which “damps” oscillations inherent in springs. It’ll rotate freely with respect to the spindle, the spindle’s movement being controlled by control arms.
While I’m not a stickler for nomenclature, the “strut” in the recent post (three posts prior) really is just a coilover shock and not a strut. It does not control the movement of the spindle other than to absorb and dampen impact. I felt it important to point that out I order to be clear regarding the difference.
What does part 7 in the diagram above bolt to, top and bottom? The top I presume bolts to the body or chassis, and the bottom bolts to what? The lower control arm ? The steering knuckle?
Bottom hinges at number 4 on the diagram.
Exactly.
It bolts to the lower control arm exactly where the arrow from the number 4 is pointing.
The top bolts to the upper mount in the strut towers.
So is part 7 a strut? Or not a strut? Since it doesn’t bolt to the steering knuckle, I’m presuming it is not a strut, right?
It’s certainly not a McPherson strut.
Not a strut.
Simply an air shock.
Used front and rear (look at your Corolla).
But no steering knuckle in the rear? I thought it had to bolt to the steering knuckle to be a McPherson strut.
I see. So if a rear strut is bolted to the hub it would still be a McPherson strut. I’m pretty sure the rear strut on my early 90’s Corolla is bolted to the hub assembly. So that makes it a rear McPherson strut then?
The 2005 Corolla design the corresponding part appears to be bolted to the axle ass’y, right? Not the hub. I wonder why motivated the design change?
Not necessarily.
The thing that makes a strut a strut is not what it’s bolted to. The thing that makes it a strut is that it controls the movement of the wheel through its suspension travel rather than simply absorbing bumps and damping oscillations. To do that it needs to be bolted solidly to the hub or steering knuckle, but a shock could also be bolted to the hub… with the wheel’s movement controlled by control rams.
Focus not on where the damper is bolted, but rather what it does. What it does is what makes it a strut. Or a shock.
Did you mean to type “control arms”?
On my Corolla it is bolted on the top to the body, sort of in front & even with the trunk lid. On the bottom it is bolted to the hub ass’y. But the hub has arms fore and aft that control its movement relative to the body, as well as a bar from one side to the other that controls lateral sway.
LOL, yup. Nice catch.
What year is your Corolla? I’ll post an image of its rear suspension.
- That is, I must say to reach the 10 character limit, 1992
Very informative TSM. Thanks for taking time to explain. Yes, that diagram you posted is what it looks like. Now I think about it, rather than dual arms going fore and aft to control the hub geometry, there’s actually two parallel arms going forward from the hub to the chassis, presumably 48710J and 48780A, and part 48730A is actually vertically oriented, and attaches the hub to the sway bar which goes over horizontally to the hub ass’y on other side of the car.
I’m not sure why they show 710 J at right angles to 780A. I think those parts are parallel. That’s a curious thing.
I think 780A is a fore-aft link, and 710J and 730A are the lateral links. Slide under your Corolla and have a look.
