I do recall that the original tires on my father’s '66 Galaxie 500 only lasted about 12,000 miles, but on the other hand, the original tires on his '63 Plymouth were good for well over 30,000 miles.  It all came down to brand quality in the long run.
And, since my friend made the mistake of buying expensive tires for his Tempest (and since he did not rotate them), the front ones were good for over 25k, while the rears were worn out (only on the inner edges of the tread) by 10k or 11k.  On this car, it would have been necessary to rotate them very frequently if they were to wear anywhere near evenly.
The Tempest featured a rear-mounted transmission and it was touted as having “perfect balance” as a result of having more weight in the rear than RWD vehicles normally do.  However, very few owners (or independent mechanics) ever thought to check the transmission fluid by pulling up the trunk mat and removing a cover in order to access that transmission dip stick.  The result was early failure for all too many of those transmissions.   While I am not positive about this one point, I don’t think that the car featured a LSD.
Rather than use a conventional drive shaft with a couple of u-joints, GM used a flexible shaft (I forget the term for this) that ran in a couple of bearings underneath the car.  The bearings were placed so that the shaft actually curved underneath the car as it went from the engine to the transmission.
The placement of the transmission in the rear meant that the flexible drive shaft was turning at engine speed, and at highway speeds, this meant that you had this thing whipping around underneath the floor at 3,000 rpm, and maybe as high as 4,000 rpms.  When the bearings gave out (well before 50,000 miles) the racket underneath the car was incredible from the combination of that inherently unbalanced engine coupled with the high speed of that driveshaft.  If this was occurring at the same time as the timing chain was hammering against the timing chain cover, it sounded like you were riding inside a garbage can, with someone banging on the outside of it.
That original Tempest was indeed very innovative.  Unfortunately, back in those days (and for many years following) GM used the consumer as their testing staff and failed to fully develop their innovative technology prior to putting the vehicle on the market.   The car was cute, and it got pretty good gas mileage.  Unfortunately, it was a piece of crap and that is why very few survived for more than a few years.
Today’s GM products actually tend to be much better in quality than GM’s half-baked innovations of the '60s
