# What is normal parasitic current drain?
**URL:** <https://community.cartalk.com/t/what-is-normal-parasitic-current-drain/20444>\
**Tags:** fuses, electrical-wiring\
**Created:** [October 6, 2008, 10:38pm UTC](https://community.cartalk.com/t/what-is-normal-parasitic-current-drain/20444 "2008-10-06T22:38:35Z")\
**Showing post:** 4
**Author:** ![willey](https://avatars.discourse-cdn.com/v4/letter/w/a9adbd/32.png) [@willey](https://community.cartalk.com/u/willey)\
**Post date:** [October 6, 2008, 11:03pm UTC](https://community.cartalk.com/t/what-is-normal-parasitic-current-drain/20444/4 "2008-10-06T23:03:44Z")
92 milliamps sounds high. I think it should be around 50 milliamps.
Did you wait about 30 minutes before checking the amp draw? When the battery is disconnected then reconnected it takes about 30 minutes for everything to power up then shut down. So if you didn’t wait long enough you could be getting a false reading.
_[View the full topic](https://community.cartalk.com/t/what-is-normal-parasitic-current-drain/20444)._
