You added a wire to provide battery voltage while cranking the engine but now there is no power in the run position. You need to bypass the resistor wire as it is not needed for this ignition system and repair the ignition power wire to the coil.
Hard to tell from your picture, but it looks like you put the new red wire on the wrong small terminal at the starter relay, should be at the one that had nothing attached to it.
Also did you leave the other wire that was at the coil + terminal hooked up?
lol … you seem to be on the right path anyway. The starter relay on my truck has one terminal labeled “s” which is an input to the relay. It is 12 volts when the key is in start, 0 volts otherwise. When 12 volts the relay’s internal switch connects the battery to the starter motor, cranking the engine. The relay has another terminal labeled “i” , which is an output. Inside the relays there’s a switch that connects the battery directly to the coil positive terminal when “s” is 12 volts. So when “s” is 12 volts, the engine cranks and the coil has full power to make a bright spark. When the key returns to “on” (from “start”), the switch inside the relay disconnects the battery voltage to the coil (and to the starter). To keep the coil powered while engine continues to run, there’s another wire from the ignition switch to the coil positive that starts as 12 volts at the ignition switch, but it is a resistor wire, so by the time it reaches the coil it measures about 8 volts, which is enough to keep the engine running, but not enough to start it.
Seems like the OP has left the building…Nope, still here!
I guess those old cars weren’t as simple as he thought they were…
OP posted 30 minutes ago, probably has another appointment now. I guessing OP is starting to enjoy the experience. Newspaper puzzles aren’t easy to solve but I still enjoy trying to solve them. Here’s one that I found quite difficult
Two rectangles, one is 5 X h, the other is W X H, and larger, has both twice the area and twice the perimeter. What are the dimensions of both rectangles? All dimensions are exact integers.
The coil+ terminal does not need to be run through the starter relay at all, it needs to be wired into a 12V keyed run position… the resistor wire needs to be 100% eliminated from the entire ignition system…
If you can’t figure that out, you can always run the coil+ wire to a toggle switch and mount it somewhere under the dash or in the dash… Temporary if needed until you can get this all figured out… Just make sure the OEM coil+ wire is not able to short to ground anyway…
You can add a seperate 4 or 5 terminal relay (link posted in prior link) if needed…
BTW, The corroded wire (that you posted a picture of) requires replacing…
The “I” terminal on the starter relay/solenoid is only energized with 12 volts while cranking., it has nothing to do with the engine running.
It’s only used to supply the full 12 volts to the coil while the key is in the “CRANK” position so it will start, once the key is released to the “RUN” position this wire is no longer being used.
His car already runs, he’s just not getting voltage while cranking.
I know how it works…
That is why it is NOT needed, if the resister wire is not used then that means that the I terminal is NOT needed as the coil will have 12V all the time period not just when cranking… again, any and every time the key is in the RUN position, the coil+ terminal HAS to have 12V… SO I will say it again, the starter relay does not in anyway need to power the ignition coil at anytime while running the MSD ignition system on the OP’s mustang…
This is a modified vehicle/ignition system, NOT STOCK and the standard wiring NO longer applies… lol
This is a VERY simple 3 wire distributer on a very simple engine/car… Stop over thinking it… ![]()
In the last picture it looks like the OP wired the coil to the S terminal on the starter relay, that is why it now starts but dies as soon as he lets off the key… AGAIN No coil wires should be run to/from the starter relay in anyway shape for or fashion on this MSD system…
Whether that wire is needed on the “I” terminal or not depends on the internal configuration of the ignition switch. One way or another, 12V must be supplied to the + terminal of the coil both during the start cycle and the run cycle.
Anyone have access to an old Motors manual or Glenn’s motor manual from the late 60’s? They used to have wiring diagrams in them.
Edit: I just looked up the ignition diagram from a 65 Ford/Mercury shop manual on the oldcarmanualproject.com site and there is no internal connection in the ignition switch to provide power to the coil in the start position. It gets power from the “I” terminal during start.
I understand it’s been modified, but on a 60’s Ford, there is only 1 wire that supplies voltage to the ignition system when the key is in the “CRANK” position, that wire is from the “I” terminal on the starter relay/solenoid.
If this system was modified correctly, the OP wouldn’t be here asking for help.
I also have a suspicion he removed the wire that was connected to the coil +, as to why it now starts but won’t stay running, it needs both of those wires on the coil + to start and run.
Before, won’t start, runs good. Now, starts good, won’t run. With classic cars, seems it’s always something … lol … I’m guessing OP almost has the ignition part of the problem solved, but has some more work ahead to solve the accelerator pump problem.
Yeah I didn’t realize that (or forgot it lol)…
Well def needs the one on the I for cranking (as y’all said), but only needs key on 12V while running…
The OP technically can run one wire (inline fuse maybe) from the battery to the coil+ and bypass everything else including the big relay… Just to see if the thing will start and run normally…
So if the OP would just hook the one new wire he hooked to the Relay S terminal in the picture to the battery+ (able to remove fast to turn car off) and see how it starts and runs… Once we knows that it works like that, then he can wire it up properly…
Very true…
Yep, that’s if he comes back.
One of Fords better ideas, there’s easier ways to do it.
Got it started on Friday. 3 cranks. Went for an hour long cruise.
Spent 6hrs trying to get it started yesterday without success.
Got it started this morning on 3 cranks again. Drove it directly to the garage it is being stored at for the winter.
Thanks for the support.
Try it again in April
Well thanks for telling us what you did different???..??.. ![]()
Would be nice to know since a lot of us are putting in a lot of time on this… lol
I said I’d be back in April. So here I am to.share the cause of the problem. It was the electric choke. It was loading down the 12V to the ignition. I removed the 12V from the choke and the car starts right up on 1 crank. This has been repeated 3 days in a row.
Congrats on finding the trouble-maker there Quig! My truck’s electric choke – the electric part anyway – hasn’t worked in 20 years … lol … but as long as driven at least once every week, it still starts right up, idles, & runs well.
As I understand how those electric chokes work, even though they are powered all the time the ignition is “on”, they have an internal switch that turns the heating coils off after they reach operating temperature. So their only function is for the first few minutes after a cold start, presumably to lower HC emissions. After the warm-up time, they no longer do anything.
With no electric choke good idea to make sure the thermo-siphon tubes are connecting & heating the choke ass’y. I had to install a new tube-connector on my truck b/c the old one fell off the exhaust manifold. Visually follow the choke-heating tubes to make sure. There should be one from the air cleaner (or carb) to the exhaust manifold, and another (usually metal) from the exhaust manifold back to the choke ass’y. If your choke plate is completely closed w/a cold engine, engine off. Then it pops slightly open as soon as you start the engine. Then it gradually opens all the way as the engine warms up over the course of 3-4 minutes, you should be good to go.
I’d have never guessed your symptoms could be caused by a presumably shorted-out electric choke. That was a tough one.
One question remains though: On my Ford truck I think the electric choke is powered directly from an alternator winding, not the 12 v from the battery. Done that way presumably so the electric choke is only powered when the engine is running. Is your Mustang’s different?
My old chev had the vac pull off line plugged for my choke by previous owner. Never ran good upon starting till I figured it out. Had to dig into it.
I guess the configuration varies engine to engine. There’s no choke-related vacuum hose for my Ford truck. The choke ass’y is bolted to the carb using a gasket, and the vacuum path which pulls the heated air into the choke’s coil-spring thermometer gadget is internal, passes through a hole in that gasket. You’d think that hole would clog up w/time and cause the choke to stop working, but it never has.
Or maybe the vacuum hose you had a problem with was for the choke pull-down? There’s no vacuum hose for that function on my Ford either.
