# Universal tire pressure of 35 psi?
**URL:** <https://community.cartalk.com/t/universal-tire-pressure-of-35-psi/142470>\
**Category:** General Discussion\
**Created:** [June 18, 2019, 1:51am UTC](https://community.cartalk.com/t/universal-tire-pressure-of-35-psi/142470 "2019-06-18T01:51:01Z")\
**Showing post:** 20
**Author:** ![CapriRacer](https://sea1.discourse-cdn.com/cartalk/user_avatar/community.cartalk.com/capriracer/32/22_2.png) [@CapriRacer](https://community.cartalk.com/u/CapriRacer)\
**Post date:** [June 19, 2019, 12:21pm UTC](https://community.cartalk.com/t/universal-tire-pressure-of-35-psi/142470/20 "2019-06-19T12:21:28Z")
> [@mperry\_153483](#):
> What are your thoughts on tires losing a couple pounds per month?
1 to 2 psi pressure loss per month (for passenger car tires) is considered by the industry to be the upper limit of acceptable. I suspect this goes back to the first days of tubeless tires as this was in place when I first arrived, hasn’t changed in 50 years , and the vast majority of tires don’t experience anything even close.
I also suspect that this value is so high because tire dealers don’t want to have to deal with fixing it - for which they don’t get any revenue.
So I think a 1 to 2 psi pressure loss per month to be worthy of finding out where the seepage is occurring. A common culprit is corrosion of alloy wheels. But I would do this myself (instead of having a tire dealer do it) using a spray bottle of soapy water. Once the problem area has been found, then take it to a tire dealer to get fixed.
_[View the full topic](https://community.cartalk.com/t/universal-tire-pressure-of-35-psi/142470)._
