Even though almost everyone considers himself to be a superior driver, I have also seen a lot of evidence over the years that many people are not able to recover from a rear wheel spinout.
You forgot to add: “When driving too fast for conditions.”
I rarely buy two new tires. The only reason I can think to buy only two are that you can’t afford four or you neglected to do the proper maintenance on your car by rotating the tires every 5,000-10,000 miles. Rotate your tires on a routine basis, and you won’t have this problem.
If you’ve neglected your car, or you can only afford two tires at the moment, put the new tires on the back. It’s safer in hazardous conditions, and when you get the other two tires replaced in 2-4 weeks, you can have them put on the front since they will wear faster than the rear tires, but 2-4 weeks of wear won’t be enough of a difference to matter. Then, all you have to do is rotate your tires and never have this problem again.
Oh, and I recommend you pay extra when you buy the tires for road hazard protection and lifetime balance-and-rotate service. Paying in advance for a rotate-and-balance service means you can get the service done on time, even when money is tight.
Yup, that’s an absolute part of it.
We have a really bad highway onramp with a rise just before the highway in Manchester. Some years back I was coming down the highway in a snowstorm and saw a young kid coming down the onramp that clearly wasn’t going to successfully merge. I slowed down early and the car behind started honking. He/she stopped honking when the kid coming down the onramp slid right across the two lanes of highway, spinning, and bounced off the Jersey barrier back into our lane… backwards. Fortunately, he then managed to slide back off the highway into the berm on the other side. That one will stick in my mind forever as a lesson to watch all around me, anticipate, and react under the worst-case assumption.
And that can happen in the most unsuspecting ways… It’s all well and good to specify but nearly impossible to insure. Surfaces change and even if you think you are driving slow enough for the conditions, all of a sudden you are not when crossing a patch of ice, cold wet asphalt or bridge when all was well an instant before. That’s why car manufacturers build in understeer and tire makers want you to put the good tires on the rear.
Oh, and a point not mentioned… Correcting a FWD skid is very different than correcting a RWD skid. Both require counter steer but RWD is off-throttle and FWD is ON-throttle, especially with a manual transmission. Very counter-intuitive to one raised on RWD in the snow.
That’s why I buy my tires from Costco. Their installation price includes a road hazard warranty (which provides for free puncture repair and a free replacement tire if the punctured one is not repairable), and lifetime balance and rotation. When you factor those services into their price it is difficult–if not impossible–to beat their prices on premium-grade tires.
unless they cannot balance a tire.
I bought tires a while back from a reputable national chain, and they tried twice and could not balance the tires. Took the car to Pep Boys (!!) and everything was fine.
So a lifetime balance service can be useless.
…IF that “reputable national chain” hasn’t opted to buy Hunter GSP9700 Road Force Balancing equipment… Luckily, Costco does use that equipment, and I would theorize that Pep Boys probably also uses it if they were able to rectify an imbalance problem that eluded the techs at your national chain.
In fact even the auto shops at the local county vocational school now utilize that superior equipment, so I have to wonder about that national chain that you patronized.
me two, specially when they blamed the steel wheels for the problem. Pep boys had no problem, didn’t mention anything about road force balancing…
Didn’t know about road force balancing then
Actually it’s a local chain, New England, but they have a few dozen stores.
Either their technician was incompetent, or they are not using up-to-date equipment–or both.
I don’t think that there are any other likely explanations.
You are Air Force I am Army Aviation. We have had “Situational Awareness” thoroughly pounded into our thick skulls. Other drivers? Not so much.
I don’t have military training, but I have enough common sense to know that when I’m driving a controlled-explosion-powered ton of metal around many others that I’d best be aware at all times. Of course as you point out, that is not always the case for many.
It’s interesting, I will never know how many accidents that training has kept me out of, but I’m sure it must be a great many. I tried my best to drill that into my kids when I taught them to drive. I’d ride down the road with my daughter pointing out all the opportunities for accidents to happen as I’d see them. The number of possibilities every time we’d go on the road was astounding, more than I’d realized. My son grew up much more observant and already had the instinct. It’s served him well… especially, I’m sure, on a “special ops team” deployment in the mountains of Afghanistan in 2012. He returned a changed man, as all who go to war do, but has never spoken of it. I’ve let him know that I’ll be there for him if he ever needs to, but I understand why he’s never spoken of it. He’s also middle-age, still serving, and has never been in a car accident. I’m sure that his situational awareness has served him well in his driving too.
Just FYI on Costco’s policy. I recently read their policy while waiting for new tires to be mounted. I didn’t commit it to memory but they will move the better tread depth to the front up to a limit. It is only when the difference exceeds a certain amount that they wont do that. So if you are getting your tires rotated on a regular schedule, you should not exceed that difference.
