Want to know how to tighten a driver side front door handle (it also has the window buttons on it). The plastic piece is loose and there are no visible screws on the bottom of the door handle to tighten.
The screws are probably hidden behind small plastic covers. They’re there, you just have to search for them.
I’m assuming you’re talking about the large plastic part you use to pull the door closed, not the latch handle you use to open the door.
Yes - it’s just the handle not the latch and I will find them…thank you for your help!
It may be screwed from the other side, and you have to pull the door handle and tighten the screws that go the other way.
