Thoughts on these A/C numbers
Ooops! My bad! Thanks.
Yeah, that’s why the static pressures seemed normal to me. I figured it is pretty much filled proper amount but considering the alternative, dumping a small amount more in there to hopefully keep it off the floor may keep it limping along. I lean more and more toward the doomsday scenario thinking about how it performed in the testing above. But maybe I can eek one more summer out of it- I’m probably not that lucky but worth at least a shot…
The static pressure at ambient temperature tells you if the system has enough refrigerant.
It seems clear that something weird is going on inside of the system re: those pressures, but I’m not the right guy to ask about that.
But I’ll also tell you my “story” about my '02 Envoy which should be pretty much identical. Even if it’s not part of the issue now, there’s a good chance it will be at some point - and maybe soon. A couple of summers ago on hot road trips I’d get in the truck and the A/C would be great. Then it would just randomly die and start blowing ambient. Sometimes it would kick back in. But often not until things cooled down again.
Anyway…it turns out that it was the clutch which worked when cool, but not so much hot. I measured the air gap and it was right at the outside of the range. (I forget the specs, sorry). Unfortunately, the last I knew you couldn’t buy a new clutch only - had to get the whole compressor. Ugh. I pulled the clutch, pulled the shim washers and then fashioned a washer that put the air gap at the low end of spec. It’s been flawless ever since.
Before I did any diagnostics or took any pressure data, one of the thoughts I had was along the same line regarding the clutch. They wear and the gap gets larger. I am also familiar with inductive coils like this developing susceptibility to heat soak. I held a screwdriver near the coil when it was working and then not. It was clear that when it was working, there was magnetism and that went away when the clutch stopped. I even tried nudging it with a stick to see if it was marginal but that was a big nope…
Unfortunately, I found out shortly after that the low pressure switch was activating (that’s another common failure in these) and then measuring the pressures and watching the gauge match the switch activation, I knew it wasn’t the coil, clutch, switch or the HVAC controller…that seemed to leave- low refrigerant level, partially obstructed orifice, dirty evaporator or weak compressor. The potential for the dessicant bag being a problem didn’t occur to me until Dave pointed that out. The static pressure seemed very much in-line with the pressure charts I had so my hopes of a low charge were on life support. That’s when I figured I’d seek input from the more experienced members here and am very thankful for all of your contributions to this discussion!!
Oh, forgot to mention- early on I was looking around to see if I could buy just the clutch and I did find one place that sells a replacement clutch kit. I never went so far as to see if I could actually gain enough access to the compressor to replace just the clutch but watched some Youtubes of guys doing just that on other cars. That would have been a nice option :grinning: with only 158k on the clock, I was hopeful the compressor itself wasn’t failing…
Do you think you know what the problem w/your car’s AC is now?
On a recent Best of Car Talk podcast Ray says he’s having trouble with his home fridge. He phoned GE, who came a did a service, but it still wasn’t working. Maybe refrigerating systems are just meant to be frustrating! … lol …
First, my gut tells me that Tester is right about the orifice, but…
I’m betting that you have a set of feeler gauges, and it’s pretty easy to get those down there. I think the spec is .02-.03" or something. Mine was a bit over .03. The magnet might be energized, but if that gap is too big, it won’t be a strong enough field to pull it in. It’d take you like 5 mins, so I’d at least check it.
This going back a couple of years now, so my memory is fuzzy on it… And everything I am saying rests on the assumption that things didn’t change from '02 (my 4.2L Envoy) to '08 (your 4.2L TB). But I found one and only one. And it had to ship from China, and I think through Ali Baba or something. And the wiring had to be monkeyed with - not in any big way, but it’s not plug n play. And it’s really tight to work on and not so easy. Things might have changed by now. I’ll look again if needed.
Again, assuming the same set up (in which case the compressor is way down low on the left side of the engine under the left of the fan) - it’s very tight down there and not easy. But I managed to finagle a 3/8" air ratchet down there which buzzed the nut off. I don’t recall the electrical connector, but I managed it with no bad memories, so it is do-able.
Not yet but I will certainly post back when I do. Unfortunately, I have an issue with my foot where I can’t stand or put any pressure on it. Hoping to be back on my feet (literally) in a few days.
Two years ago now, it was early November IIRC and I noticed one of the central air systems for my house running at less than 1/2 speed. It was cold enough for the furnace so that was odd. I flipped the outside cutoff and waited for some warmer weather to check it out. No signal from thermostat, fan running at 1/2 speed, compressor motor doing same. After checking the start/run cap and relay, I measured the motor windings and it fit all the tell tale signs of a compressor motor that was in black death mode. Closed it back up and waited for spring. Spring came and started looking around for someone to replace the system. Then I got curious and went back to re-measure the motor windings. Strangely, they were different. So I took more of the cabinetry apart to get better access. That’s when I found a mouse had chewed through the wiring and made a nest. Two years now (knock on wood) it’s still running. Ran for 36 hours almost straight the other day…Sometimes, things have a happy ending :grinning:
It was fairly obvious with the screwdriver between when the coil was energized and the clutch pulled in versus when it wasn’t running. It’s a pretty easy and down and dirty check. At the back of the coil by the connector, the field is pretty strong and you can easily feel the screwdriver drawn in versus when the coil is not energized. Plus, if you recall, I said I manually pushed the clutch plate in with a stick and it still didn’t engage. That was just a what the heck, why not try and see if the air gap is too big or the coil is weak. I didn’t even bother hooking up a meter at that point. When I did measure the low pressure switch with my meter, it was easy to see it activate electrically so I knew that was responsible for turning off the compressor clutch.
I like that- with no bad memories!
Pretty sure this is the one I ran across:
The low pressure switch turns voltage off to the compressor clutch if the pressure drops too low to prevent damage to the compressor.
But I think in your case, it’s too late.
