The most efficient friction brake ever used in automobiles. Period
I am the one who threw gasoline back on the smoldering fire. I was away for a month and came back and checked in and decided to respond to posts that I had missed.
Its amazing how emotional people can get (me included) over brakes. I like drum brakes, they have a history, they are not appreciated for their benefits, although I admit they have some drawbacks as well.
Since the weather is terrible in many places of the country I will add that one disadvantage of drum brakes is when they are used in a semi they have a tendency to get stuck in the applied position when the rig is parked in freezing weather, this does not apply to cars unless the parking brake is applied.
FWIW, I dont believe there are any semi truck trailers in the USA that have disc brakes on the trailers.
I like music from the 40s, 50s and 60’s much better than todays music, but I am not going to argue with the young people today. My iPod, my music. Your iPod, your music. OK?
Rick, there’s a reason it happens on trucks and not on cars. On truck trailers, the brakes are designed such that they’re engaged when the air compressor is off, called a “normally energized” design. So when the truck is parked, the shoes are always engaged. It’s a safety feature so that if the truck loses power it applies the brakes rather than losing the brakes. Car drum brakes are designed “normally deenergized”, which means that unless they’re applied they are not engaged. Thus, when cars are parked their shoes are not engaged unless through the parking brake linkage.
In short, truck brakes are always applied by default when the truck is parked. Car brakes are always not-applied when the car is parked unless intentionally applied using the parking brake system.
On a semi-trailer, only the emergency brakes are applied with loss of air pressure, not the regular pedal-actuated brakes.
Thanks for the clarification.
Final clarification: the service brakes and the emergency brakes use the same shoes and drums. Both actuators operate the same rod at each wheel.
Ah, from whence came my confusion! {:stuck_out_tongue:
Here is a thought, If you had to drive a vehicle with non power brakes would you rather it be equipped with drums or discs?
I would take drums with non power brakes.
If a vehicle were designed from the ground up to have non powered brakes, I don’t think you still have to compromise and have drums. You can gain lots of mechanical advantage that eliminates the need for power brakes. The brakes in a tractor (and other HD vehicles) are non powered discs that will control the tractor and full tow weight of thousands pounds down a steep grades.
The NEW 2016 Tacoma has retained drum brakes in the rear. With a lower percent of total braking done by the rear, better off road protection, integration with a solid axle design and simplicity use as a parking brake, Toyota felt they work fine…on the rear where much less braking is required and is more of an “after though” used more for steering control that sometimes cause more harm then good otherwise.
"I was away for a month and came back..."
Back on parole, eh?
Surely there’s a middle ground; say drums on the left side and discs on the right.
Then you have the best of both worlds… :wink:
Here is a thought, If you had to drive a vehicle with non power brakes would you rather it be equipped with drums or discs? I would take drums with non power brakes.
My motorcycle has non-powered disk brakes and there is no way I would go back to any of the non-powered drum brake motorcycles I have ever owned.
Why not just agree that disc brakes are better in most automotive applications, but drum brakes have their place too–it all depends on the application.
Yep good point. Let the engineers decide. 14 pages is enough discussion on this one me thinks.
I have owned 4 compact cars with manual disc brakes and I don’t recall any short comings.
I converted two 4000# vehicles from manual drum to (front) disc and both stop in a shorter distance and straight, a necessity on crowded city streets.
