If I had a leak wouldnt I be losing fluid? In the 3 years I have owned it I have had to put psf in once back in the fall and then it was not y hat much it was just below the full line and I like to keep it at the line.
I give up!
bertrand, it’s an internal leak. Look - you asked and you were given the suggestion. If you don’t like the suggestion then just do something else.
I am just asking if there us a leak wouldnt it show up by less fluud in the reservoir?
The fluid is bypassing internally in the power steering rack. This is why the steering is sluggish.
