Does your truck have an automatic or manual transmission? If it’s an automatic just shift into neutral when you have the no-start problem. If it starts it’s probably a bad neutral safety switch. If it’s a manual then the neutral safety switch is on the clutch. It can cause the same no-start symptoms. Have you cleaned the battery posts and cables?
| Starting issues, etc. with 1997 Chev truck v8 | 13 | 1958 | May 1, 2016 | |
| Truck won’t Start please help | 18 | 873 | October 10, 2019 | |
| Truck wont crank | 21 | 2358 | June 14, 2015 | |
| Why sometimes no cranking at all? | 6 | 625 | June 20, 2009 | |
| Truck wont start occasionally | 23 | 939 | February 14, 2023 |
