# Should I change Transmission Fluid?
**URL:** <https://community.cartalk.com/t/should-i-change-transmission-fluid/198663>\
**Tags:** transmissions, camry, toyota\
**Created:** [January 10, 2025, 11:06pm UTC](https://community.cartalk.com/t/should-i-change-transmission-fluid/198663 "2025-01-10T23:06:04Z")\
**Showing post:** 12
**Author:** ![Cavell](https://sea1.discourse-cdn.com/cartalk/user_avatar/community.cartalk.com/cavell/32/43396_2.png) [@Cavell](https://community.cartalk.com/u/Cavell)\
**Post date:** [January 12, 2025, 2:27pm UTC](https://community.cartalk.com/t/should-i-change-transmission-fluid/198663/12 "2025-01-12T14:27:29Z")
Watched video on Camry fluid change. There is a fill port on side of trans you reach thru wheelwell. Seems easy drain 2qts fluid. Measure it. Put that amount back. Do it 2-3 times over summer.
_[View the full topic](https://community.cartalk.com/t/should-i-change-transmission-fluid/198663)._
