There’s a specialty bit available that sort of looks like a pineapple (or maybe a better description is what a differential pinion gear looks like, only smaller). I’ve never tried it, but the idea is you grind the end of the stud flat, then use that to make a bowl-shaped depression. Then when you start drilling, the bit naturally starts at the bottom of the bowl, which is the center of the stud. I’ve not been able to find a picture of what it looks like b/c I don’t know the name of that type of bit. I’ve seen it as part of bolt extractor sets in hardware stores.
Related topics
| Manifold bolts are rusted tight | 10 | 18695 | June 13, 2008 | |
| What Should I Do about Rusty Bolt | 26 | 1716 | June 16, 2020 | |
| Rusted nut on stud problem | 16 | 1646 | June 4, 2017 | |
| Frozen exhaust manifold bolts | 5 | 1388 | July 19, 2008 | |
| How do I get this rusty Exhaust off? | 33 | 11378 | February 3, 2020 |
