Rhino Ramps and Oil Change Questions
I think you’ll be OK, if you have 6.5" of clearance. Comments say, “About 6.5” high. The ramp is 22" long to the flat so can run a pretty low profile vehicle up the ramp". Measure ground distance from the low spot to the base of the tire. If less than 28", you’ll be going up the ramp and clear the ramp lip. Ones like that worked on the Neon when it still had 6" ground clearance. I also prefer to use a pair of wheel chocks for the back tire.
Hi,
I have a 2016 Honda Fit and bought the 17 degree Rhino Ramp and it does NOT clear the bumper. I have a makeshift ramp that I use for my truck that I put together from wood that graduates to three inches high and I put it in front of the Rhino Ramps and it works fine that way. I hope this helps.
