Replacing tires on an AWD vehicle
If you had a front wheel drive or rear wheel drive (instead of all wheel drive), then you would only have to match the tread depth on the two tires on the drive axle.
For example, if Ruby Sue was front wheel drive (instead of AWD), you could move you existing rear wheels and tires onto the front (they have the same tread depth), move your good front wheel and tire to the rear, and replace your bad tire with a new one, and put it on the rear on the other side.
There is a difference between circumference of a tire and “rolling circumference”. The rolling circumference is the circumference of the tire as it is rolling down the road with the vehicles weight on it. You can have virtually identical circumference between tires, but when they roll down the road ten times, there can be a big difference which will cause damage to drivetrain components.
It is true here is the video that proves it http://www.michelinman.com/tire-care/tire-saving-tips/replacement-questions/
