Photo is excellent. Having the actual data always helps greatly. Thank you.
However, I’m still wondering, is it the operating problems that are causing the mechanic to suggest a new cat converter? As I mentioned before, a converter can be restricted and cause poor operation without causing a check engine light or an emissions failure. Also, was there a fault codes stored in the ECU?
