Radiator replacement...to flush or not to flush?
If you’re replacing the radiator, then yes, most of the coolant will be removed.
It depends on the vehicle/cooling system how much that is.
Ask the shops who just want to do a drain and refill how much more it’ll cost to open the drain cock plug from the engine block so it gets drained too.
