Push Button Horn Installation
The OP didn’t use that kit. I found conflicting specs on the switch that was used; 5A or 4A. The horn sheet says use 10A fuse but not current draw expected from horn. I suspect the switch could work if nothing else a few times before it would fail. The fact it was DOA seems to indicate defective switch or perhaps a wiring error.
I would use a relay regardless of the switch rating myself…
George, you need to get out more . . .
Radio Shack is no more
https://www.radioshack.com/products/12vdc-spst-automotive-relay
That relay with a default pin #87a is as common as vanilla ice cream and found on HELP aisles
and most everywhere that auto and electronic parts are sold.
