I think that is a possibility.
I can recall that a friend of mine had this exact rear-end side-hop problem with his Explorer, and the cause turned out to be a broken anti-sway bar link.
The ballast helps the ride. I’m just hoping it doesn’t need any thing more than shocks. I bought the truck from a friend last spring for $1500 drove it from Oregon to Montana, and then poop hit the wind machine. I have put $2000 and lots of hours into it so far. The thing is only worth the $1500. I replaced the bearings and all brake components all around and looked at the suspension while the wheel were off. Didn’t see anything. Maybe I didn’t want to see any thing.
NO NO NO! I don’t want to have to replace everything under there. Tired of working on this thing. I’ll just take it to a priest, have him bless it and then sell it as soon as possible.
An anti-sway bar link is actually a pretty small component. So, I don’t foresee that you would be replacing “everything under there”, and the cost (if I am correct about it being a broken link) shouldn’t be very high.
Does this truck have a rear anti-sway bar?
One thing that’s easy enough to do, get out your tape measure and with the truck parked on a level surface, check if both sides are riding at the same height. I think it is normal for there to be some difference front vs rear, but if the ride height is different right vs left, that would provide a clue where to focus to determine what’s wrong. Just a guess, but as mentioned by others above, it sounds some kind a rear leaf-spring or shock absorber problem to me.
Well the shocks came and I put them on that night. That was the problem. Now I feel a lot safer. Thank you everyone for the input. Michael
Thanks for posting your solution.
@andriy.fomenko seems to be the big winner here. With that big check he’s getting we can look forward to him taking us all out to dinner this weekend.
so my poke into the dark room resulted in loud MEOW!!!
few weeks before I removed struts/shocks from my “new” 2006 Pathfinder with 150K miles and they were so rusted that I could barely move the rod on one of the back ones, thus the guess
congrats on getting it fixed to @mrgrudz!
