My Friend's Daughter's Philippine Market Toyota 2024 Vios - Observations:
My priority at the time was a car with a moonroof.
Honda’s base accord with 60-series tires doesn’t have one.
Oh I do understand the need for it.
I was being sarcastic about Americans not being able to cope with setting different tire pressures front and rear.
This just FURTHER confirms you’re the king of hypocrisy :crown:
If you PRACTICED what you preach, you would have bought that base model Accord with the 60-series tires
A 2005 Accord EX had I believe 60-series. Problem is, by 2020 when I was Carguru’ing Hondas, there were few 7th Gen Accords around with less than 100,000 miles, let alone the 71,000 miles on my 2010 8th Gen.
Plus, the 7th Gen stereo had an Aux input button, but no actual jack!
That had to be installed separately by the dealer, or the aftermarket route.
You’re talking to someone who has already experimented, with positive results, with using staggered front/ rear pressures.
Again, I was joking about Americans not knowing their correct cold tire pressure at all, let alone being able to comprehend different values for different axles.
You don’t get to hurl insults and then say you were just “joking”
It doesn’t work that way around here
Here we go again. Might wanna just lighten up a little. You don’t have to respond to every comment. Two fairly frequent posters have already been driven off. Just ignore what you don’t like. I don’t know if it was the profanity that seems to be ok here or not but why keep going back and forth like two year olds?
