@hebe - if its the actuator, I can certainly see needing to remove the dash to get to it. That is never cheap, but $1600 is still highway robbery for it. A heater core replacement in your truck should cost $640-833 according to repairpal (for my region - $556-$709 of that is labor). That’s pricing it at around 7-9 hours of labor. The actuator in this case is significantly cheaper than the heater core, so the upper bound of costs should still be what a heater core replacement costs, since labor should be similar. Heck, with those actuators so cheap, there’s a strong argument for replacing them ALL if you DIY the job when you’re in there.
You might want to shop around for a different shop, though, not simply because the price was too high. Every once in awhile, someone figures out a trick that speeds up replacement and they might pass some of that savings through. For example, some mechanics found that for some Tauruses, you could cut a little support bracket used for installing part of the dash, and then you didn’t need to actually remove the dash to replace the heater core - you had to remove a few bolts so you could move it slightly, but it eliminated all the wiring disconnects and such and cut a 7 hour+ job into a 2 hour job.
