Master Cylinder Bleed
Here’s the brake bleeding procedure when the master cylinder has been removed, reinstalled, or replaced.
  • Connect a scan tool to the vehicle.
  • Start the engine and allow it to idle.
  • Depress the brake pedal firmly and maintain steady pressure on the pedal.
  • Using the scan tool, begin the automated bleed procedure.
  • Follow the instructions on the scan tool to complete the automated bleed procedure. Release the brake pedal between each test sequence.
  • Turn the ignition OFF and remove the scan tool from the vehicle.
  • Fill the brake master cylinder reservoir to the maximum-fill level with GM approved brake fluid from a clean, sealed brake fluid container.
  • Bleed the hydraulic brake system.
  • With the ignition OFF, apply the brakes 3–5 times, or until the brake pedal becomes firm, in order to deplete the brake booster power reserve.
  • Slowly depress and release the brake pedal. Observe the feel of the brake pedal.
  • If the brake pedal feels spongy, repeat the automated bleeding procedure.
  • If the brake pedal still feels spongy after repeating the automated bleeding procedure inspect the brake system for external leaks.
  • Turn the ignition key ON, with the engine OFF; check to see if the brake system warning lamp remains illuminated.
  • If the brake system warning lamp remains illuminated, Do not allow the vehicle to be driven until it is diagnosed and repaired.
  • Drive the vehicle to exceed 8 mph/ 13 km to allow ABS initialization to occur. Observe brake pedal feel.
  • If the brake pedal feels spongy, repeat the automated bleeding procedure until a firm brake pedal is obtained.
