No, the 3.4 was never offered as an option, which is what made me wonder. Then I found the 3.4 is a bored/stroked so-to-speak 3.1L. That made me think it’ll work. The junkyard dogs all said it was a bolt-in replacement, but I still wasn’t convinced enough to spend $250 for the 3.4, so I consulted Google, (because if it’s on the net, it’s GOT to be TRUE! J/K) and referenced a bunch of different people saying it’s possible, but haven’t done it themselves, and had own ideas of problems.
Then, I guess some bored mechanics had one from an 02-03 grandam laying around, and for some reason decided to put it in a malibu. So to shorten the thread, they looked it over, decided it looked like it should work, & put it in, thing fired ul and ran fine. So, then said bored mechanics started changing things out, like PCM’s and a couple transmissions, and started documenting what was going on in that thread. They finally decided that leaving it as a bolt in motor, not changing the PCM was the easiest. I guess when they changed the PCM to the 3.4 PCM the VIN wasn’t syncing with the other computer, and threw a code, kept fuel pump off. I found that on one of the grandam forums from '05 era. This made me think it’ll work, so I’m going to pick it u tomorrow.
Like I said, I have absolutely no idea if this will work, it seems to point to that it’ll work, with basically a bolt-it-in, plug-n-pray theology. But, if it doesn’t, at least I have an engine that’s assembled, which seems to be a better position than one in pieces/buckets with questionable bearing races. I’ll keep working on it, and see what I come up with, and post details as I come across the problems, if any.
Btw, does ANYBODY know how to R&R an engine/transmission and NOT end up with extra bolts/nuts/parts? The answer always seems to be that’s impossible, LOL
