That is the same conclusion I arrived at. Nothing else explains the behavior. I took the truck out again today and there was no pedal sinkage. For the present, it ain’t broke and I ain’t gonna fix it.
Did as you suggested RK and adjusted until pounding the brakes no longer loosen the slight drag.
On second reading, not quite sure what you mean by that, but the the face of the pedal is 5 1/2 inches from the floor at rest and 3 1/2 inches when the brakes engage. That seemed like quite a bit when I measured it, but it feels much higher at the engage point than before the shoes, master and wheel cylinders were replaced and the system bled and the brakes manually adjusted. I am assuming at this point that the self-adjusting mechanisms haven’t been doing their job, which, from my google searches, is not entirely uncommon.
I’m will be keeping my eye on the top of the plastic rez on the MC to see if it continues to leak from the caps.
Heart-felt thanks to all for the feedback.
Jack
