# Impotent 2001 Nissan Sentra seeks a VIAGRA-like solution!
**URL:** <https://community.cartalk.com/t/impotent-2001-nissan-sentra-seeks-a-viagra-like-solution/89942>\
**Category:** Maintenance/Repairs\
**Tags:** nissan, sentra\
**Created:** [May 12, 2015, 12:23am UTC](https://community.cartalk.com/t/impotent-2001-nissan-sentra-seeks-a-viagra-like-solution/89942 "2015-05-12T00:23:32Z")\
**Posts on this page:** 20\
**Page:** 1
<div class="post-metadata">
**Author:** ![Nissan\_blues](https://avatars.discourse-cdn.com/v4/letter/n/90db22/32.png) [@Nissan\_blues](https://community.cartalk.com/u/Nissan_blues)\
**Post date:** [May 12, 2015, 12:23am UTC](https://community.cartalk.com/t/impotent-2001-nissan-sentra-seeks-a-viagra-like-solution/89942/1 "2015-05-12T00:23:32Z")
</div>
I’ve read the threads but found none that may apply.
My car is diseased; being a scientist, I want to do more than just say a prayer and a Hail Mary in the hopes that it gets to the top of the hill!
Runs fine on flats and downhills.
In February 2015, an “engine light” indicated that my catalytic converter was malignant. Had it changed.
THe mechanic noticed that the car had little activation energy (i.e. acceleration and delivery of power was not directly proportional). I had it too, but, thought nothing of it. He suggested changing all 4 spark plugs. I agreed. For the first three months, the car exploded going on uphills.
It’s now May 2015, and the car feels impotent - has an engine, but doesn’t deliver on power. I accelerate, the motor’s RPM goes higher, but the output is slow. What is slow? In uphills, slow aking to having to be with the big rigs and trucks.
Would anyone be so intrigued as to provide a course of treatment?
Thank you for your attention,
Nissan Blues
**Author:** ![shadowfax](https://sea1.discourse-cdn.com/cartalk/user_avatar/community.cartalk.com/shadowfax/32/13026_2.png) [@shadowfax](https://community.cartalk.com/u/shadowfax)\
**Post date:** [May 12, 2015, 12:48am UTC](https://community.cartalk.com/t/impotent-2001-nissan-sentra-seeks-a-viagra-like-solution/89942/2 "2015-05-12T00:48:15Z")
</div>
Manual transmission? get on a hill, go 15mph, put it in the top gear, and floor it. If the RPM rises rapidly but the car doesn’t accelerate, you have a worn clutch and need a new one.
**Post date:** [May 12, 2015, 1:00am UTC](https://community.cartalk.com/t/impotent-2001-nissan-sentra-seeks-a-viagra-like-solution/89942/3 "2015-05-12T01:00:38Z")
</div>
Hello Shadowfax;
it’s not a manual transmission car. Automatic transmission.
Any other leads?
**Author:** ![Docnick](https://avatars.discourse-cdn.com/v4/letter/d/ecae2f/32.png) [@Docnick](https://community.cartalk.com/u/Docnick)\
**Post date:** [May 12, 2015, 1:15am UTC](https://community.cartalk.com/t/impotent-2001-nissan-sentra-seeks-a-viagra-like-solution/89942/4 "2015-05-12T01:15:08Z")
</div>
There is no Viagra type of solution for cars.
A slipping automatic and a thoroughly incompetent mechanic could be your problem. In medical terms, your mechanic is a quack!
A proper engine evaluation will determine whether your compression, fuel system air intake, etc. are up to snuff. “Exploding” applied to an engine is not a very scientific term. What actually happened?
**Author:** ![VDCdriver](https://sea1.discourse-cdn.com/cartalk/user_avatar/community.cartalk.com/vdcdriver/32/30_2.png) [@VDCdriver](https://community.cartalk.com/u/VDCdriver)\
**Post date:** [May 12, 2015, 1:31am UTC](https://community.cartalk.com/t/impotent-2001-nissan-sentra-seeks-a-viagra-like-solution/89942/5 "2015-05-12T01:31:13Z")
</div>
**“I accelerate, the motor’s RPM goes higher, but the output is slow.”**
This is a classic symptom of either a slipping clutch or an automatic transmission that is…unwell.
Since the OP has already told us that the car has an automatic transmission, then the clutch issue can be ignored.
The OP should do the following:
> Immediately check the level, color, and odor of the transmission fluid, and then report back to us on his findings.
> Start asking friends, neighbors, relatives, and co-workers for the names of recommended independent transmission shops. (Do **NOT** go to Lee Myles, Cottman, Mr. Transmission, or _\<\>_ AAMCO.)
> Start looking for a new mechanic for non-transmission-related issues.
For future reference, the OP should try to remember that automatic transmissions need to have their fluid and filter changed every 3 years or 30k miles–whichever comes first. On the basis of elapsed time, this vehicle should have had that service done at least 4 times so far. If that hasn’t been done, then the OP should consider that the major factor in why his transmission is now failing.
**Author:** ![BillRussell](https://sea1.discourse-cdn.com/cartalk/user_avatar/community.cartalk.com/billrussell/32/3179_2.png) [@BillRussell](https://community.cartalk.com/u/BillRussell)\
**Post date:** [May 12, 2015, 1:32am UTC](https://community.cartalk.com/t/impotent-2001-nissan-sentra-seeks-a-viagra-like-solution/89942/6 "2015-05-12T01:32:24Z")
</div>
If you could leave out words like: exploded, impotent, viagra, and describe exactly what your problem is, it would help.
**Post date:** [May 12, 2015, 2:12am UTC](https://community.cartalk.com/t/impotent-2001-nissan-sentra-seeks-a-viagra-like-solution/89942/7 "2015-05-12T02:12:26Z")
</div>
Thank you all for your suggestions thus far.
In response to DocNick and BillRussell requests:
I am going uphill, am accelerating, and the car is moving slowly.
I’m at about 65mph, RPM’s is abouy 4-5, and the car is moving upwards at a speed of that of a gas tanker.
In response to VDC Driver, I will check the color, odor, and level of my transmission fluid - and report back tonight.
Thank you for your attention, Nissan Blues
**Post date:** [May 12, 2015, 2:25am UTC](https://community.cartalk.com/t/impotent-2001-nissan-sentra-seeks-a-viagra-like-solution/89942/8 "2015-05-12T02:25:12Z")
</div>
**“I’m at about 65mph, RPM’s is abouy 4-5, and the car is moving upwards at a speed of that of a gas tanker.”**
This is just more evidence of a badly-slipping transmission.
If the OP is VERY lucky, it will turn out to be merely a case of a low level of fluid in the trans, but–of course–that also indicates the probability of a transmission leak, so even in this best-case scenario, the services of a good independent transmission shop will be necessary.
Can the OP please tell us about the service history of his problematic transmission?
**Post date:** [May 12, 2015, 2:44am UTC](https://community.cartalk.com/t/impotent-2001-nissan-sentra-seeks-a-viagra-like-solution/89942/9 "2015-05-12T02:44:55Z")
</div>
VDCDriver,
Is OP short for operator?
I have no prior history of a problematic transmission.
What is the functionality of a transmission fluid in the operation of “giving power” to the car?
I will take a picture of the transmission fluid as well tonight.
**Author:** ![Nevada\_545](https://sea1.discourse-cdn.com/cartalk/user_avatar/community.cartalk.com/nevada_545/32/41232_2.png) [@Nevada\_545](https://community.cartalk.com/u/Nevada_545)\
**Post date:** [May 12, 2015, 2:47am UTC](https://community.cartalk.com/t/impotent-2001-nissan-sentra-seeks-a-viagra-like-solution/89942/10 "2015-05-12T02:47:31Z")
</div>
Badly slipping transmission?
How do you know what gear it was in? The engine speed may be appropriate for third gear.
BTW, 65 MPH is not slow for a Sentra on a grade.
**Post date:** [May 12, 2015, 2:56am UTC](https://community.cartalk.com/t/impotent-2001-nissan-sentra-seeks-a-viagra-like-solution/89942/11 "2015-05-12T02:56:16Z")
</div>
**“Is OP short for operator?”**
OP is internet talk for _Original Poster_, namely…you.
**“I have no prior history of a problematic transmission.”**
Okay…fair enough…perhaps this was a poorly expressed thought on my part.
I will rephrase is as…_Can you give us the service history of this transmission that now appears to be problematic?_
(Translation=How many times was the trans fluid changed over the past 14 years?)
**Author:** ![MG-McAnick](https://sea1.discourse-cdn.com/cartalk/user_avatar/community.cartalk.com/mg-mcanick/32/188_2.png) [@MG-McAnick](https://community.cartalk.com/u/MG-McAnick)\
**Post date:** [May 12, 2015, 2:56am UTC](https://community.cartalk.com/t/impotent-2001-nissan-sentra-seeks-a-viagra-like-solution/89942/12 "2015-05-12T02:56:37Z")
</div>
OP = Original Poster. That’s you Nissan blues
It sounds like a slipping transmission to me. By slipping I mean that the RPM goes up, but the car maintains the same speed.
**Post date:** [May 12, 2015, 2:58am UTC](https://community.cartalk.com/t/impotent-2001-nissan-sentra-seeks-a-viagra-like-solution/89942/13 "2015-05-12T02:58:34Z")
</div>
Nevada\_545
Hello!
When the spark plugs were changed in Feb 2015 (please refer to my original posting), I saw a substantial change in power. I had power.
Recently, the (lack) of power has reversed to what i’ve observed as early as Feb 2015. There is something amiss with my car.
**Author:** ![BustedKnuckles](https://sea1.discourse-cdn.com/cartalk/user_avatar/community.cartalk.com/bustedknuckles/32/25_2.png) [@BustedKnuckles](https://community.cartalk.com/u/BustedKnuckles)\
**Post date:** [May 12, 2015, 3:06am UTC](https://community.cartalk.com/t/impotent-2001-nissan-sentra-seeks-a-viagra-like-solution/89942/14 "2015-05-12T03:06:38Z")
</div>
I would pull a spark plug or two and look for fouling. A noticeable performance drop that quickly smells of trouble internally.
**Post date:** [May 12, 2015, 3:06am UTC](https://community.cartalk.com/t/impotent-2001-nissan-sentra-seeks-a-viagra-like-solution/89942/15 "2015-05-12T03:06:41Z")
</div>
VDC Driver,
Don’t shoot this OP, but, in the time that I’ve owned it (2003-onwards) and keeping a comprehensive maintenance records (just a quick aside: after 100K, I contacted the Nissan headquarters and asked them what do I do now since your car maintenance log only goes up to 100K), I am unaware of any one moment in time when my transmission fluid was drained and added a clean batch.
I can go a few step forwards: When I’ve taken it to a Nissan dealer and other independent mechanics for engine oil changes, their responses (because I asked) was: “all other fluids are fine; no need to change or add more.”
Frustating to me to have to write this response.
**Post date:** [May 12, 2015, 3:10am UTC](https://community.cartalk.com/t/impotent-2001-nissan-sentra-seeks-a-viagra-like-solution/89942/16 "2015-05-12T03:10:34Z")
</div>
I told my Parents that I wanted to take a mechanic class in high school instead of photography. Now I would at least know about changing spark plugs around or being cognizant of all fluids need to be changed - no matter what.
**Post date:** [May 12, 2015, 3:22am UTC](https://community.cartalk.com/t/impotent-2001-nissan-sentra-seeks-a-viagra-like-solution/89942/17 "2015-05-12T03:22:00Z")
</div>
Thank you all for your suggestions. I greatly appreciate your time and attention.
I would like to summarize them so that I have a game plan:
1. action: change transmission fluid desired behavior: see if I have power uphill
2. action: check for transmission fluid leak desired behavior: fix it
3. action: check my 4 spark plugs integrity desire behavior: I don’t know understand how spark plugs is connected an increase in engine power.
4. action: check transmission desired behavior: ???
If there are other ideas or comments I will continue to compile a strategic list.
Nissan Blues
**Post date:** [May 12, 2015, 3:32am UTC](https://community.cartalk.com/t/impotent-2001-nissan-sentra-seeks-a-viagra-like-solution/89942/18 "2015-05-12T03:32:07Z")
</div>
It sounds like an engine performance problem, I doubt you will be able to find the problem on your own. You will need to have a mechanic inspect and drive it.
If the engine has a failing spark plug or ignition coil the check engine light should be flashing and it would be difficult to reach 65 MPH on flat ground. A transmission won’t slip for long at that speed without burning up, perhaps 60 seconds. You are going to have to have someone diagnose the problem.
**Author:** ![ok4450](https://avatars.discourse-cdn.com/v4/letter/o/e9bcb4/32.png) [@ok4450](https://community.cartalk.com/u/ok4450)\
**Post date:** [May 12, 2015, 4:30am UTC](https://community.cartalk.com/t/impotent-2001-nissan-sentra-seeks-a-viagra-like-solution/89942/19 "2015-05-12T04:30:25Z")
</div>
My first suggestion would have been to run a compression test while the spark plugs were out. Granted, you state that the engine had power after a plug change but some of that could possibly be due to the placebo effect.
If the engine is getting a little tired spark plugs will start downhill. With new plugs a slight improvement may be noted but will be short-lived.
I’m a firm believer in making sure the engine has the gumption to do the job; ergo, the compression test.
If compression is good then transmission slippage comes to mind. A converter stall test could be easily performed but I don’t know whether to recommend that or not as it would be easy for someone to finish an iffy transmission off while doing the test. Done right it shouldn’t be a problem.
**Author:** ![circuitsmith](https://sea1.discourse-cdn.com/cartalk/user_avatar/community.cartalk.com/circuitsmith/32/40376_2.png) [@circuitsmith](https://community.cartalk.com/u/circuitsmith)\
**Post date:** [May 12, 2015, 6:11pm UTC](https://community.cartalk.com/t/impotent-2001-nissan-sentra-seeks-a-viagra-like-solution/89942/20 "2015-05-12T18:11:11Z")
</div>
**"He suggested changing all 4 spark plugs. I agreed. For the first three months, the car exploded going on uphills. "**
Did the mechanic use OEM plugs?
For a Japanese car that would be NGK or Denso brand of the same part number in the Owner’s Manual and usually on a label on the underside of the hood.
Here’s a little science for you:
The manufacturer designed and tested the engine with a spark gap of a certain size and position within the combustion chamber.
Number and shape of ground electrodes affects shrouding of the flame front.
These are important to performance and critical in some (often with Japanese) designs.
Can you count on another brand meeting those specs? Not always.
For driveability problems I always recommend getting the valve lash checked/adjusted and a compression test.
[Next page](https://community.cartalk.com/t/impotent-2001-nissan-sentra-seeks-a-viagra-like-solution/89942.md?page=2)
