# Ignition switch key will not turn
**URL:** <https://community.cartalk.com/t/ignition-switch-key-will-not-turn/204209>\
**Tags:** neon, dodge\
**Created:** [October 7, 2025, 4:54pm UTC](https://community.cartalk.com/t/ignition-switch-key-will-not-turn/204209 "2025-10-07T16:54:45Z")\
**Showing post:** 2
**Author:** ![davesmopar](https://sea1.discourse-cdn.com/cartalk/user_avatar/community.cartalk.com/davesmopar/32/41750_2.png) [@davesmopar](https://community.cartalk.com/u/davesmopar)\
**Post date:** [October 7, 2025, 6:44pm UTC](https://community.cartalk.com/t/ignition-switch-key-will-not-turn/204209/2 "2025-10-07T18:44:46Z")
> [@Neon ignition switch won’t turn to lock](https://community.cartalk.com/t/neon-ignition-switch-won-t-turn-to-lock/201184):
> Car starts runs fine. Everything works. Key just won’t turn to lock. Key can’t be pulled out. Steering does not lock. Have to unplug battery if sitting for a king time. I assume it’s a bad switch.
Last time you said it won’t turn to lock, this time you said it will not turn…
Does it turn any?? or doing the same as last time and won’t turn to lock??
_[View the full topic](https://community.cartalk.com/t/ignition-switch-key-will-not-turn/204209)._
