Lots of PB spray, if you can heat them with a torch. As a person whos broken a few bolts my best advice if they are small (like tranny pan bolts, though any bolt in general) is loosen a bit and if they get tight turn them back in a ways then loosen again. Might take a while but well worth the time. If there is enough space for a socket wrench PVC pipe can add leverage.
