Well, now that you’re heard from all the people who have either not owned one, or had rented one for a couple of days, how would you like some first hand experience with one that has been owned since they first came out in '01?
My gf has had her car since it first came out, and was one of the ones who was on the original waiting list after the car was shown at the car show the previous year. In fact, her car was actually ordered by someone in Canada, but they backed out of the deal at the time of delivery, so the car was sent from the dealer in Canada, to her dealer in Colorado.
She has ~80k miles on it now, and hasn’t had any real trouble with it yet.
The rear window wiper motor is the only current issue, aside from an occasional stumble at idle.
The car was originally supposed to be built on the Neon platform, like a few people have mentioned, but Chrysler dumped that idea during the initial design phase, as that platform wasn’t strong enough to deal with the added weight and stresses.
As for working on the car, yes, its harder than your average FWD 4 cylinder car.
Why they designed the intake manifold runners to run over the top of the engine, and block the center two spark plugs, I’ll never understand. Changing the spark plug wires requires the removal of the upper intake plenum, which increases servicing costs, and takes longer.
Also, access to the accessory belts is restricted by the design of the front end of the car, and isn’t easy. Not to mention doing a timing belt change. This is a car they should have used an engine that had a timing chain in it. That would have been a much better idea. Too bad no one makes a retrofit kit. They would make a fortune.
As for every other part on the car, its standard Mopar issue parts.
Dirt cheap, and easy to obtain. Transmissions are from other cars. Suspension is from other cars. Brakes are from other cars. Etc.
Driving the car, the manual transmission gets more out of the engine than the automatic does. I would get Transman’s opinion on the Chrysler automatic transmission. I’ve never heard the word reliable ever used in the same sentence with their automatic FWD cars. My gf has the 5 speed manual in her car, and hates automatics with a passion.
She loves her car, and won’t ever replace it.
She did, however, buy an '08 Chrysler Crossfire Roadster the other year.
She just loves the styling on both cars. The Crossfire is Art-deco, while the PT Cruiser is Art-nouveau. Two entirely different driving experiences, also. And the initial reliability on the Crossfire had been the exact opposite of her PT Cruiser experience.
The Crossfire went back to the dealer during the third month, where is stayed for a full month, and had over $12k worth of warranty work done to it because a single nut that holds the grounding wires from several computer blocks wasn’t properly tightened at the factory in Germany.
Now back to the PT Cruiser…
Its excellent in winter driving with good snow tires on it.
Hasn’t had any issues with starting in cold or foul weather.
The emissions test done on it last year showed that everything was well within spec, so its not a gross polluter.
Its got plenty of headroom, and comfortable driving position.
It is very flexible, as the rear seats come out, and you can use it as a cargo hauler.
The seats do weigh a ton though!
Its a fairly heavy car, and is quite tall, so handles the way a vehicle like that should. It does fine up here in Denver, between 5k and 13k feet, going up the high altitude passes to get to other places. She’s driven it to Missouri in comfort, and it returned decent fuel economy.
It is what it is.
If a bargain is what you are looking for, then the PT Cruiser is a very good bargain.
Insurance is cheap. Repair costs are fairly low, until you get into big ticket repairs, like the timing belt.
If a good car to get you too and from work is the most important item, the PT Cruiser will fit the bill. If the styling turns hit you the right way, then its probably the best car out there for you.
You either like the styling, or you don’t.
There really isn’t any middle ground in that department.
Anyway, the cars are good, and won’t blow up when you turn the key, unless you piss off the mob.
BC.
