Heater only works well in warmer temperatures
Wondering how many shops use distilled water for coolant changes.
Tester is right, unless you remove the drain plugs in the block, you don’t get all the coolant (or water after you flush it). This is why I don’t like 50/50 coolant. The Pink extra long life coolant for my car is not available in anything except 50/50.Toyota says it is good for 10 years at the factory fill but only 5 years after you change it.
Next summer I will drain what I can flush it with a garden hose and add the correct amount of a full strength coolant and fill the rest with water. I will then mix up a 50/50 mix for the remote reservoir and for topping off.
I have never used anything but tap water. I think it depends on the quality of your water.
I have a Toyota and change my own coolant also. I always assumed that Toyota assumed you wouldn’t get 100% of the old coolant out, hence the 5 year change recommendation after you do a drain and fill. If it was good for the first ten years, I can’t see any reason it wouldn’t be good for ten years again if you could totally flush the system and get 100% new coolant in there?
I did a drain and fill on our 2013 at 100k miles. A little early going by years, but obviously 100% of the coolant wasn’t replaced by just removing the bottom radiator hose. I’ll do it again in 2023 or so. Then every 5 years. It’ll never all be new coolant in there, but it’ll never be all old coolant either. I figure it’ll work out well enough.
I think it depends on where you live. Tap water near me has low dissolved solids, and should not be significantly different from distilled water. Well water would be a different story.
