No return line, just one line coming in.
Thanks for the update
This is what I’d do
Hook up a fuel pressure gauge
Perform an injector balance test
If all is well, the pump is almost certainly your problem
How do you perform a balance test on injectors?
2 ways
1st way
Scan tool + fuel pressure gauge
2nd way
Fuel pressure gauge + this tool
http://www.sears.com/otc-fuel-injector-tester-otc3397/p-00918197000P?prdNo=1&blockNo=1&blockType=G1
Here’s the idea
Prime the fuel system
Note the fuel pressure
Buzz the injector with the tool, or the scanner
Note the second reading
Do the same with all injectors
All injectors should drop the same amount of pressure
If one doesn’t drop at all, it’s no good
It one doesn’t drop enough, it’s restricted
If one drops too much pressure, it’s also no good
I’ve found many bad injectors with this tool
Interesting.
Are you pretty handy?
Would you be able to replace the pump yourself . . . after your diagnosis is complete?
Yep, I changed it in my C1500 pickup. Turns out in the Escorts they are in the back seat so no need to drop tank or anything just gotta pull the cushin out back seat. Might have to see if I can rent a scan tool.
FYI . . . aftermarket scan tools do NOT have the injector balance test for Ford vehicles
However, you may want to make sure there’s nothing else going on
Here’s a cheaper tool for buzzing those injectors. It doesn’t have the capabilities of the other one, but it might be sufficient for occasional use
I see. I’ll see if my Dad has one or if all else fails see if I might be able to get it done at the college (free since I’m a student).
Well ran the tests looks like its probably a fuel pump issue. Pulled out the back seat and removed the cover last night, will be taking it out and replacing it today. Will say this is much simpler than replacing the fuel filter on these things:)
Ran into an issue. Got to removing the locking ring and well shes RUSTED BAD. Took brass drifter and one of the pins broke off (almost all of them are gone, tapped one to another). Sprayed with PB and removed some of the gunk, any other ideas of all else fails?
