OK, two of you good people tried to warn me about AZ fuel pumps. Too late now but I’ll know next time.
I have the Trugrade pump in my tank, which is cleaned and dried. Fuel pump O ring and top not screwed down yet.
Question: This made ij China pump came with two clips, one white, one black (see photo), which I’m not certain of their intended use.
New pump has no instructions in box at all, no parts included list, the scan code covers cleaning a fuel tank but not the product itself, the AZ web site same thing, the one guy at the local store who might know WTF with the clips is off for next two days!
Old pump that came out of the car had no such clips.
Since this new fuel pump packaging included one brief sheet instruction for wiring a GM module (!) which is not needed for this Ford, I’m assuming that the clips might be included for use only for wiring up a GM connector and thus not needed at all for this particular applicatioj in a Ford?
Any advice on this will be much appreciated. I’m finally ready to get this new pump sealed tight into the tank and tank installed into car. But I don’t want to do all that to only then find out I screwed up by not using the clips.
Thanks as always!
