Okay. So THAT didn’t fix my noise either. More on that later as I have ANOTHER theory…
I replaced the water pump the afternoon is blew out. But this brings me to a side question. Please settle this for me.
On first install of the timing belt I had to tension the eccentric pulley without the special tool. Yesterday I used the special tool.
My side question is in relation to the eccentric pulleyand its relationship to the hydraulic tensioner/damper.
See attached Pic;
No. 1 Image is how I tensioned the eccentric. In that I went in the opposite direction recommended in the workshop manual. I did this so that, as I turned the eccentric (with the special tool), I was applying downward pressure onto the hydraulic tensioner rod - pushing it back into the tensioner body. I only applied enough pressure on the rod to loosen the locking pin holding the tensioner rod in place. I then torgued the eccentric holding bolt down.
No. 2 Image shows the recommended direction that I apply pressure to the eccentric. This, to me (and my limited experience), would take pressure off or away from the tensioner rod.
No. 3 Is an image from an FTO workshop manual. I’ve included it because it shows that as pressure is applied to the eccentric pulley the tensioner arm acts on the tensioner rod. This to me seems to be the correct way to do things.
Am I thinking outside of the box here or what? Is there an expert on Mitsubishi timing belts here that can set me straight?
Now, back to my exhaust leak and my NEW (and improved) theory. The stock headers, where the y-pipe flange meets the header flange, has a raised or extended section of pipe that fits up into the headers. Neither of my aftermarket headers have this extended/interlocking arrangement. See attached hand sketch - top sketch = my new theory, bottom sketch = the stock headers pipe vs’ flange arrangement. My new theory is to press in a short section of pipe, into the aftermarket headers y-pipe, to recreate the arrangement seen in the stock headers.
I dont think I’m getting the sealing action at my flanges and/or my two mating flanges are moving about too much. I “sort of” tested this theory by running tape around the flanges… sure, it melted and made a mess, BUT I think it proved my theory correct.
Going to have a crack at it tomorrow.
