This is potentially a relatively simple job. As others have already mentioned there are several things, especially rust, that can complicate the job. I happen to live in Southern California where rust isn’t usually severe and I’ve removed and/or replaced a number of catalytic converters (and other exhaust components) from Toyotas and Hondas (bolted). I’ve been fortunate in that so far I’ve never had a big problem removing catalytic converter fasteners. However, exhaust systems are inherently rusty so I know my luck can run out anytime. I will say that unless the fasteners are in excellent condition I will replace them with new ones when I reassemble. My point is the project is doable but it depends.
AlanY
10
| Fix or junk my daily commuter? | 71 | 732 | October 8, 2024 | |
| Repair for almost-but-not-stolen catalytic? | 54 | 16055 | February 28, 2021 | |
| Getting rid of the catalytic converter...will that cause problems? | 63 | 34168 | January 15, 2008 | |
| Honda Civic 2003 Catalytic Converter Replacement | 14 | 3431 | July 22, 2020 | |
| Replace Catalytic Converter and O2 Sensor or get a new car? | 56 | 6659 | November 11, 2019 |
