db, I did work in manufacturing and we used a variety of air tools. The 3/8 drive ratchets would not torque a tire, they did work for the smaller connections we had, on the larger ones, when the ratchet stopped, it locked so the operator could add a quarter or half turn as needed for the connection. Air impact wrenches would keep hammering on the connection but it would take a long time to get tight, longer than the operator wanted to spend.
For some critical applications, we had some 1/2" drive air ratchets that were preset to 75 ft lbs of torque, again just shy of the needed torque for a tire though.
Currently I buy all my tires at my local Costco. The use an impact wrench to run down the nuts, but the air supply is regulated to a low pressure so it only puts about 25 ft/lbs on the lug nuts. The tires are hand torqued from there. They do a lot of tires everyday.
One of the local Sam’s Club’s here has invited me to never buy tires from them again. Their procedures are supposed to be the same as Costco’s but I noticed that they hammered down the lug nuts with the air impact wrench so much that the torque wrench only just clicked, it did not move the nut. I discussed the proper way to use a torque wrench with the manager but he did not appreciate my valuable advice.
Another tire store that had been recommended by a coworker pretty much ruined the rims on my truck when I took it there for tires. The pin headed moron who installed the tires hammered down on the rims with an air impact wrench with those useless “torque sticks” He did not center the rim properly and with each wheel in an offset from the center, he proceeded to hammer down on the first nut until it deformed the hole on my alloy wheels. I went to the manager about it but they would not take responsibility for their lousy workmanship.
I had to take the truck to Costco and get the tires rebalanced and reinstalled, and it helped, but the wheels still did not quite center on the holes, had to finally remachine the chamfer for the holes myself to get the truck to ride smoothly.
I will give you one thing though, I don’t believe that rotors can be warped by the use of an impact wrench. The only way that over/under/inconsistent torque would warp a rotor would be if it was mounted on a cantilever, which it is not. Just like the over heating theory, I think this is another myth.
