Probably normal, since a piston fires every 90 degrees of crankshaft rotation. Here’s the best I could find for firing order:
The three on compression should be in order in the firing order, i.e., 4-3-6, etc.
I have to move the throttle very slowly in order for it to rev, and yes i would like to reach redline
In the case of that picture, 1,3, and 7 were all in compression at the same time.
Do you think it is just really bad carb tuning?
Puzzling…all I can suggest is pulling the plugs and distributor cap and verifying the correct firing order and valve movement. Mark the plug wires before removing to be sure to keep them straight. Mis-routed plug wires is a common problem. (My diagram could be the wrong one for your engine.) Is the firing order shown on the block anywhere?
Two more ideas:
Check timing mark on harmonic balancer…it may have shifted.
If everything looks perfect, try moving distributor one tooth each way.
The 1 and 8 cylinders are in the right places
How are you determining TDC? The best way is a thin rod through the spark plug hole feeling for the piston. If you can see the top of the piston, that works also.
Is the engine an AMC?
From the reports here, the most common reasons why an engine won’t increase rpms from idle like it normally should as you push on the gas pedal are from among
If I had this problem on my truck here’s the order of tasks I’d do to try to diagnose/fix it
The accelerator pump may not be working, check the operation of the accelerator pump in the carburetor.
