I know this thread is old but I was wondering if you ever found what the cause was. I have a 2008 V6 3.5L Chevy Impala and it does the exact same thing. Once I rev the engine above 4k rpm the AC starts cooling and works fine afterward even if you shut off the car and start it again. But if it sits for a while, then you have to rev it up to 4k again to get the AC working. I don’t have the tools to measure the pressures on the AC lines but it seems like it is the exact same problem you were having.
Jung_Moon
21
Related topics
| AC Works only when engine is revving high | 23 | 122947 | July 27, 2023 | |
| Air conditioner not very good or something wrong? | 52 | 3500 | July 4, 2021 | |
| AC blowing hot at idle but cold at higher rpm | 7 | 10469 | June 22, 2020 | |
| Bad AC comp or add just freon? | 14 | 138 | June 6, 2026 | |
| A/C Recharging | 1 | 362 | June 7, 2009 |
