Can I just keep adding oil?
It is the beginning of the end, the very beginning of an end that is still a long way off. Add oil as needed and keep up with the normal oil change interval, this car still has a long life ahead.
But do check the oil frequently, if it gets too low, that can move the end up much closer. Probably checking monthly for now will be sufficient.
