I suspect that the problem is probably related to a vacuum leak if the carb you purchased was supposed to be set up for an MG or, as others have mentioned, it may simply be too big for the engine. I once replaced the ZS carb on my 1977 MGB with a Weber from Moss Motors and it ran perfectly right out of the box, at least after I plugged a couple of now unused vacuum ports on the manifold. By the way, this was a down draft carb. The side drafts are generally too big for a stock engine and will display similar problems as what you are experiencing. By the way, my son now owns the car and is doing a conversion to the dual SUs.
KLRTom
21
| '74 Dodge V8 360 Engine dying at idle | 54 | 40178 | November 14, 2013 | |
| MG TD losing power | 22 | 8272 | June 4, 2011 | |
| 73 Ford truck idling poorly | 54 | 9228 | May 15, 2016 | |
| Rough running MG | 12 | 4622 | April 16, 2012 | |
| Early 70's Ford 302 Engine-performance Problem | 31 | 31814 | February 9, 2020 |
