I don’t give a hoot how often anyone changes oil. You feel better changing it every night, go for it.
I do give a hoot when a reputable board like this gives out bad advice. And, most folks here who have stated an opinion, are guessing. There is no other way to describe it. This goes on year after year, never changes. Ad infinitum; ad nauseum.
http://community.cartalk.com/discussion/2279373/oil-change-every-10000-miles/p1
Look for Jotmo, he is a certified oil analyst, try page 3, and he said he would have no problem taking oil out of your car when you change it at 3,000 miles and drive it another 5,000 miles.
Reading the guessing on this board for quite a few years, I finally had my oil tested, several years ago, after letting it go 8800 miles. I wanted to know just how much you guys really knew: I found out, not much. Mobil-1 EP, around 8 year old Sienna with well over 150,000 miles, and mostly driven on the highway long distances. All parameters, including contamination, additives remaining, were good, and indicated they would stay good until an estimated 10,000 miles.
I am now working on a plan to run Dino oil 5,000 miles and have it tested, to see if dino is really just as good as synthetic as some of our guessers insist.
The best thing for those who really want to know, assuming your car is no longer under warranty, is to have your oil tested at your regular change. If you car is still under warranty, as far as I am concerned, you MUST change it per manufacturer’s recommendations, because the warranty essentially says it is the manufacturer’s motor if you want repairs paid for.
If you do not want to know, guess. That works, too. Just please don’t pass your guesses on as anything but guesses.
