Brake line cut per mechanic. foul play or normal wear and tear?
Has there been any work done on the wheel where the hose failed? If the caliper is pulled off its mount it must be supported to prevent damaging the rubber hose. Allowing the caliper to hang on the hose will often damage the hose and the damage may not result in failure for several weeks.
