# Brake bleeders keep leaking
**URL:** <https://community.cartalk.com/t/brake-bleeders-keep-leaking/140797>\
**Tags:** honda\
**Created:** [May 21, 2019, 9:02pm UTC](https://community.cartalk.com/t/brake-bleeders-keep-leaking/140797 "2019-05-21T21:02:59Z")\
**Showing post:** 38
**Author:** ![thegreendrag0n](https://sea1.discourse-cdn.com/cartalk/user_avatar/community.cartalk.com/thegreendrag0n/32/9265_2.png) [@thegreendrag0n](https://community.cartalk.com/u/thegreendrag0n)\
**Post date:** [May 24, 2019, 12:33pm UTC](https://community.cartalk.com/t/brake-bleeders-keep-leaking/140797/38 "2019-05-24T12:33:52Z")
As DIY-er, I rebuilt few sets and did not need to hone it ever, but I was already scolded by Mr. @Tester on the similar “caliper rebuild” topic here: [Use silicone grease (Sil Glyde) to protect caliper boots and guide pin boots----a good idea?](https://community.cartalk.com/t/use-silicone-grease-sil-glyde-to-protect-caliper-boots-and-guide-pin-boots-a-good-idea/140403/7)
Once, I encountered a caliper with a small rust spot, which I polished out with 2000 grit sandpaper, and I did not see any ill effects of that.
On recycled parts, I would check if it is possible to push the piston in with pressure not exceeding “reasonable”, just to make sure it is not seized.
_[View the full topic](https://community.cartalk.com/t/brake-bleeders-keep-leaking/140797)._
