That has always been the weakness of turbos. With age, the seals on the shaft between the impellar being spun by the hot exhaust and the impellar pushing air into the intake begin to allow the oil lubricating the bearings to be drawn into the induction system. The exhaust side is under pressure, and the induction side is under vacuum, the assemblage is being heated by the exhaust stream and it’s spinning at high speed.
