# Battery dies every 24 hours
**URL:** <https://community.cartalk.com/t/battery-dies-every-24-hours/189218>\
**Tags:** terrain, gmc\
**Created:** [February 19, 2023, 2:57pm UTC](https://community.cartalk.com/t/battery-dies-every-24-hours/189218 "2023-02-19T14:57:43Z")\
**Showing post:** 2
**Author:** ![davesmopar](https://sea1.discourse-cdn.com/cartalk/user_avatar/community.cartalk.com/davesmopar/32/41750_2.png) [@davesmopar](https://community.cartalk.com/u/davesmopar)\
**Post date:** [February 19, 2023, 3:39pm UTC](https://community.cartalk.com/t/battery-dies-every-24-hours/189218/2 "2023-02-19T15:39:35Z")
> [@Vampire drain on battery](https://community.cartalk.com/t/vampire-drain-on-battery/189202):
> I have a Gen 1 2000 Honda CR-V. I had a vampire battery drain and after fully charging the battery, I pulled the following fuses. Auto door locks Dome lights Auxiliary power sockets (there’s the dash and a rear socket) The vampire battery drain is gone. The dome lights were clearly in the off position prior to the vampire drain. One other item before my question, the front auxiliary socket became disconnected from the two wires so the wires are now not connected to anything and not capped. …
This is a thread about a parasitic draw that will help you on how to check for one…
But at the same time, if the lights came on about the same time then the computer is trying to tell you something, you need to find out twhy the lights are on, it is possible the 2 issues are linked…
_[View the full topic](https://community.cartalk.com/t/battery-dies-every-24-hours/189218)._
