If you mean that when you turn the key, nothing happens, no noise etc, but after turning it several times, then something happens, then it could be a safety switch. If you have an automatic, put it in neutral and see if it starts more reliably there. If so, you need a park/neutral safety switch.
If you have a manual, it could be the clutch safety switch.
