# Academic / esoteric question on early Toyota timing belt engines
**URL:** <https://community.cartalk.com/t/academic-esoteric-question-on-early-toyota-timing-belt-engines/199545>\
**Tags:** engines\
**Created:** [March 20, 2025, 12:41am UTC](https://community.cartalk.com/t/academic-esoteric-question-on-early-toyota-timing-belt-engines/199545 "2025-03-20T00:41:28Z")\
**Showing post:** 34
**Author:** ![davesmopar](https://sea1.discourse-cdn.com/cartalk/user_avatar/community.cartalk.com/davesmopar/32/41750_2.png) [@davesmopar](https://community.cartalk.com/u/davesmopar)\
**Post date:** [March 23, 2025, 2:34pm UTC](https://community.cartalk.com/t/academic-esoteric-question-on-early-toyota-timing-belt-engines/199545/34 "2025-03-23T14:34:36Z")
> [@TheWonderful90s](#):
> I’m fairly sure that all gasoline Toyota engines that use a timing belt are non interference. The interference engines use a timing chain.
You might want to do a little more research next time before posting…
### 2) Timing Belt Problems
We’re moving onto yet another issue that really isn’t a true design flaw. However, the timing belt is an important standard maintenance item. **Toyota 3MZ-FE engines are interference engines.** This means there is some overlap in the area in which the pistons and valves travel. This isn’t a problem when the 3.3 V6 ignition timing is on par.
> **[Toyota 3MZ-FE 3.3L V6 Engine - Specs, Reliability, Problems](https://8020automotive.com/toyota-3mz-fe-3-3l-v6-engine/)**
> Learn about the Toyota 3MZ-FE 3.3L V6 engine. Toyota 3MZ-FE engine specs, reliability, problems, & performance.
Pretty sure that is a timing belt…
 ![image](https://global.discourse-cdn.com/cartalk/original/3X/0/1/01b4464c1f2fdeb13d91bffd88526c3b17c217df.jpeg)
_[View the full topic](https://community.cartalk.com/t/academic-esoteric-question-on-early-toyota-timing-belt-engines/199545)._
