Check your owner’s manual and see if that weight is within the “recommended oil” options. If it isn’t, then go back with your shop order (that whoudl have the oil weight that they put in listed) and DEMAND that they correct it. Then check their work and your oil level before leaving.
And never darken the door of a Jiffy Lube again. Follow Joseph’s advice.
