# 2012 Chevrolet Equinox - 3 quarts between oil changes
**URL:** <https://community.cartalk.com/t/2012-chevrolet-equinox-3-quarts-between-oil-changes/141714>\
**Tags:** chevrolet\
**Created:** [June 6, 2019, 5:06pm UTC](https://community.cartalk.com/t/2012-chevrolet-equinox-3-quarts-between-oil-changes/141714 "2019-06-06T17:06:10Z")\
**Showing post:** 4
**Author:** ![edb1961](https://sea1.discourse-cdn.com/cartalk/user_avatar/community.cartalk.com/edb1961/32/122_2.png) [@edb1961](https://community.cartalk.com/u/edb1961)\
**Post date:** [June 6, 2019, 6:59pm UTC](https://community.cartalk.com/t/2012-chevrolet-equinox-3-quarts-between-oil-changes/141714/4 "2019-06-06T18:59:41Z")
Google “equinox oil consumption”. The oil consumption is primarily due to premature wear of the oil control rings on the pistons on the 2.4 4cyl Direct Injection engine.
This was my experience with my 2013 Equinox.
> [@2013 Chevrolet Equinox 2.4 Oil Consumption](https://community.cartalk.com/t/2013-chevrolet-equinox-2-4-oil-consumption/89727):
> In the last 1000 to 1500 miles the Equinox has used possibly up to 1/2 quart of oil. Current mileage is 29500 miles and the next oil change is due at 30k miles. Evidently this is not an uncommon occurrence with the Direct Injection 2.4 Ecotec starting with the 2010 model year. I added 1/2 qt. and will track the level until the next oil change. The oil is changed every 5k miles with 29% to 35% oil life remaining according to the OLM. No noticeable oil usage between oil changes up to 28.5k mi…
The short version, between the 20 and 25k oil changes I first noticed the oil level dropping. At 42k the dealer did an oil consumption test and the Equinox was using a quart/1500 miles. I documented all the oil changes and added oil as needed between changes. The dealer replaced the pistons, rings, and a timing chain in March 2016 under warranty. It has 84k miles at this point and oil consumption is 1/2 to 3/4 qt between 5k changes.
Based on my experience and my belief that DI engines are hard on oil I use full synthetic oil and change the oil every 5k miles.
The best thing you can do for your Equinox is check the oil level frequently and add oil as needed between changes. I’ve found it’s best to wait an hour or two before checking the oil. In my experience it takes a long time for the oil to drain down to the oil pan for this engine.
Good luck,
Ed B.
_[View the full topic](https://community.cartalk.com/t/2012-chevrolet-equinox-3-quarts-between-oil-changes/141714)._
