Where is the oil filter on the 2005 toyota highlander limited 6cyl 3.3 . If you can point me to a picture, that would be great.
Its between the fan and the engine block, under what appears to be part of the exhaust manifold. Its easier to get to once you pull off the heat shield. 3 - 10mm bolts.
Thanks, I did find a picture on edmonds
