Just keep in mind that service managers are not necessarily the best techs. They specialize in customer service, not in auto mechanics - an certainly not unusual engine problems.
If you have an oil issue (maybe rings maybe valve stem seals) it does not necessarily affect all cylinders and can easily leak enough to both ash up a plug and clog up an injector withou making it obvious on the dipstick.
Did you happen to get a clue as the the numbers from when the compression was tested?
I think the trouble is with the ECU as others have already stated. The ECU may be turning the injector on too long or there may be a problem with a current limit resistor for #2 injector inside the ECU. If I was working on this I would use a O-scope to compare the signals across the injectors. It will show how well things are working.
#1 is a little fuzzy, but it’s got a lot of miles on it.
The iridium electrodes can hold up for 100k miles or more, but the rest of the plug can pick up deposits just like a conventional one.
None of the center insulators show signs of running rich (would be dark).
No sign of oil burning. #3 and #4 look like they run a little cooler than the others.
I plan to change the plugs in my '06 Matrix at 50k mi.
Update…after a bit of push and pull with the dealer, they agreed to contact a Toyota FTS for ideas. Apparently the FTS agreed there was likely a problem and suggested some tests. They also got approval to (tentatively, anyway) cover the cost of repairs. I took it in yesterday (Monday) morning and they still have it today. I just spoke to the repair adviser…didn’t get all the details, but it sounds like they have the head off and have noticed an issue with oil consumption on #2. “Block” was mentioned, but I didn’t catch the context. Apparently they need parts, and are looking at having it ready Thursday or Friday, including the injector. I’ll post again when I know more.
“Cause: Found #2 cyl. burning oil, and #1 inj. bad”
“Correction: Replaced short block and all related seals and gaskets
Also replaced bad inj
120101 10.4 combo k .1 L .2 C 6.2 T1-87 T2-50”
Here are the parts they put in:
11400-22531
OEM 2005 Toyota Matrix Short Block Assembly
The car has been driving fine, and no check engine light, but mileage seems down. I called the dealer and they said that is to be expected with a new engine. Is that the case? When should I expect that it will get better?
I’ve only filled up a few times since getting it back, but while I used to get somewhere between 300-400 miles per tank, now it seems like I can’t hit 300, even with mostly highway driving.
Check the plugwires and make sure they are seated well. I would also have the coolant sensor for the ECU checked to make sure it is working as it should be. Using a scanner should show if the coolant temperature is where it should be and the sensor is working correctly.
